81 - 91 of 91 Posts
2020 White Limited Hybrid
[Off Topic] Interesting the name of a previous president is censored, but ASS isn't - lol [/Off Topic]
Administrator
[Off Topic Response] A.S.S. isn't a political timebomb..... or is it? [/Off Topic Response]
I am happy my 5th Gen does not have the Auto Stop/Start.
Reactions: walker and Darkw
I have an 2021 Outback and not a big fan of the auto on/off, and there are 3-4 button clicks to manually disable each time you start the car :-(
Two methods I've found:
1) The on/off is disabled when a trailer is connected. If you have a towing kit installed you can trick it into thinking it has a trailer on as the lights connector has a magnetic reed switch in there, so jam it open with a piece of styrofoam. The plug folds up under the bumper anyway so you don't get dirt in it. Only downside you need to consider is that the "auto braking" when on the reversing is disabled. The proximity sensors all work fine though.
2) When you pull up to a stop, just keep the break feathered on to hold you in place. It takes a little practice, but the computer thinks you are ready to go and doesn't stop the engine.
2020 Onyx
I've gotten quite good at applying JUST enough brake pressure to engage the AVH function but I rarely break the threshold of engaging the auto start/stop. It's almost like a game...
Don't like the feel when it restarts on my '21, concerned about engine or transmission damage due to starting the engine while in drive.
My software version has a button to disable it just over the driver side AC controls so the first thing I do when getting in the car is press that button. There's a setting to disable it but the setting is ignored and Auto Start/Stop gets activated every time the car is started.
2021 Onyx XT
Don't you think Subaru, and the other manufacturers have taken this into account? After all, they've been in vehicles for several years.
Subaru moved the setting to the main screen so it is more convenient to disable. They did emissions and mpg testing with autostop/start enabled. Hence why it reverts to On with each start. The other setting is really superfluous.
Why people continue to complain about it when there is a solution is a mystery.
Well aware of that, have seen it in Volvo's, GM's and others but still don't like how it feels when releasing the brake so in my case is turned off all the time.
2020 Outback Limited and 2015 Forester Limited
You can turn it off every time you start the vehicle or you can install the AutoStop Eliminator and turn it off once and forget it. It's your choice.
2021 Onyx XT
Where can I get that?
Google search for ‘autostop’ returns
81 - 91 of 91 Posts
