97 Outback 2.5L Dark Green
I have a 97 Outback withe 230000 miles, two weeks ago it would not start. I thought it was a starter issue and replaced the starter and battery. This did not help. I talked to a friend and he said it could possibly be the neutral safety switch, so I replaced it. This did not help. After doing some checking on the starting circuit I found the two blue wires that go the the factory security system were damaged. I repaired them and now it starts but will not stay running. I starts revs to 2000 rpms and the starts to drop rpms and shuts off. I tried replacing the TPS, that did not help. Also now the AT temp light is on. Can anyone please Help :confused:
