I have an 06 2.5 that has a busted timing belt. Removed the TB cover that was cracked. I was told this is a variable valve enging due to the blue solenoid. The car has 234oookms.Should I do a leak down test on the heads? Or have I for sure bent valves and should just pull the heads off? Thanks!
