I have a 2000 Subaru Outback. I keep regular maintenance on it. I'm very picky about my car, so everything gets done at the exact mileage each part or fluid change needs replaced. I deliver mail for the USPS out of my sub and recently, I started having an issue with my temp gauge slowly climbing, but only while parked after running it for about an hour. It normally stays right at 9:00 and the fans kick on if it even starts to think about moving. But a few days ago, I happened to be stopped at a box and noticed my temp needle climbing to the next mark on the temp gauge. But while I'm driving at any speed, my car stays cool and the needle doesn't move. It's currently averaging about 20F where I live. I thought maybe it was dirty and due for a flush and a change; the car has about 300,000 on it.
So I flushed it, multiple times with water, replaced the thermostat, replaced the coolant with Peak 50/50. Made sure there was no air in the system, checked for HG issues and I still have the problem. I did notice if I run my heater on max fan and max heat, the gauge never moves no mater if I'm idle or driving. The heater is hot and I have no other issues. Could this be a faulty temp gauge sensor or engine sensor?
I have asked every mechanic I could find and no one could figure out what is wrong. One person did suggest that I buy an actual Subaru Thermostat and put in the Subaru conditioner. I currently have a Duralast oem170f Thermostat in it and it's the same one I used about 2 years ago when I replaced it. The radiator is in good condition and I have no leaks in the hoses.
Any input on this would be appreciated.
