'96 Legacy Outback Wagon 2.2
Hi, I was installing a timing belt and found the tension idler bolt with the threads full of the alum from block. My question is... What to do to fix the problem. its a 2.2 1996 outback.
Just buy a new timing belt tensioner bracket. the tensioner and pulley bolt to a bracket, not the engine. so you can just replace the bracket itself. get a used one or a new one for $35 from subaru. it's held in place with like 3 12mm bolts, remove them and the bracket comes right off.
you can also repair the threads with time serts or helicoils. M10x1.25 threads.
what about the geared/toothed/cogged idler sprocket/pulley/gear??
mine crapped out, bolt broke, and cant locate Any data on what size bolt or anyone who sells replacement bolts for timing components
