2004 H6 VDC SOLD, 1996 Legacy L, 2005 Forester XS
Hello,
My buddys passenger side inner CV is stuck in the diff. Ive hit it with an air hammer, mini sledge and prybar, hit it through the diff. with a punch both by air hammer and mini sledge. My next step is to remove the trans., take the diff housing off and replace it.
I have two transmissions that are toast but I'm hoping at least one of them will work. I am wondering if anyone has any info or knows where to get it on the final drive. My buddys Outback MY is 03/04 2.5 with auto trans. I have an auto trans from a 2002 H6 and a 97 impreza. Im hoping both of the diff. housings fit and one of them has the proper final drive.
Thank you!
um, you mean the stub is stuck? you already knocked the pin out and removed the axle?
Unfortunately the cars after 04 (this car is technically an 05 I think) don’t have the roll pin. Picture the inner CV as the stub shaft and cup as one piece. I got the thing out after a bunch of persuading. The final move was to use both of the axle “poppers” at the same time. What a pain in the butt.
struggling to get the inner shaft out is a bit of a worry .... mine just popped out ... you will need to renew the C clip on the end of the shaft to make sure . they get out of shape very easy but its a main dealer only part
2005 Legacy Wagon Limited 4EAT
FWIW I use this and it works very well
That’s exactly what I used. It was very effective once I realized using both would push it out further hahaha. Thanks for the info though!
