This is pretty much an exact replica of my experience last June, same model vehicle driven by the offender even! No airbag deployment in mine either (for the other guy).
My bill was a bit over $3,000. Spare tire pan replacement is 19 hours labor, the whole lower part of the back of the car comes apart. The member that the tailgate latches to will also need to be replaced, the rear part of the spare tire well is actually part of that assembly and is likely horizontal now (mine was). Fortunately, the only visible part they have to paint is the bumper. Make sure they transfer the supports for the rear of the load floor (they attach to the cross piece with the tailgate latch), my shop missed that, I had to go back for that and the plug under the spare tire bolt.
Check EVERYTHING, look over the damage with the adjuster and look over the vehicle as you review the estimate on paper. Make sure they note everything. Look over the vehicle before accepting it back, metallic paint can be tough for them to match the way the metallic lays, and make sure they put everything back. I had to refuse mine the first time, the paint wasn't right and they forgot the step pad on top of the bumper, sound deadener and new muffler (tailpipe was dented and they included it w/o my asking), they even had the new muffler in the shop!
Here's the underside of mine after the wreck, that shiny part is supposed to face the back of the bumper, the part at the bottom should be where the under side of the bumper attaches. In the pic inside the tire well, see the seam sealer (the white line)? That's supposed to be on a vertical plane.
