1 - 10 of 10 Posts
I’d like to get Subaru center caps for my wheels. Has anyone with motegi mr118’s (or any other wheels with a center cap size other than Subaru’s) successfully found Subaru emblem center caps? Unfortunately the OEM caps where quite a bit smaller than the motegi ones. Been searching and haven’t come across any which seem to be the correct size.
2018 Outback 3.6R Limited; 2" LP Aventure lift, LPA skid plates and small bumper guard, diff breather relocation, subframe skids; Motegi MR118 17x8et32 wheels; Yakima LoadWarrior with extension; ARB
I got this link from someone who used them to get stickers that go over the Motegi sticker in the center caps. Haven't done it yet myself, but have certainly considered it. https://www.ebay.com/itm/8pc-Subaru-Center-Cap-Vinyl-Sticker-Decals-Overlay-W-Background-Circles/361765696551
I thought about doing the decals as a last resort. Don’t think they’d look as good as actual caps, and also obviously wouldn’t be as durable but they might look and work fine. That being said these ones below actually look pretty good. Gonna take measurements to make sure 56 mm will fit in the mr118 cap but I may pull the trigger on these. Will report back.
https://www.etsy.com/listing/688085087/4x-56mm-black-subaru-wheel-center-cap?gpla=1&gao=1&&utm_source=google&utm_medium=cpc&utm_campaign=shopping_us_c-electronics_and_accessories-car_parts_and_accessories-car_accessories&utm_custom1=67c5212a-39da-46b6-8615-9bd75b2b5294&utm_content=go_304502075_22746067595_78727297715_aud-537409439212:pla-106552232915_m__688085087&gclid=Cj0KCQjw7sDlBRC9ARIsAD-pDFpnk5bAuygka-TRcx4oip_l8fAmA6lvPlNnXf7zEs2fWadJ9M5ar-IaAg3vEALw_wcB
Have you tried hubcaphaven?
https://www.hubcaphaven.com/c/7350/subaru_center_caps.html
In regards to stickers, you should check out orsini, you can choose your own color scheme..
https://orsini-vinyl-designs.myshopify.com/collections/emblem-overlays
I checked hubcaphaven, the problem is that the center cap size on the mr118’s is 2.75” while the OEM Subaru ones are 2 5/16”. I couldn’t find any larger Subaru caps anywhere. Unless some of the other Subaru models use a larger cap that I don’t know about. I’ll check into those decals, thanks for sharing.
2018 Outback 3.6R Touring
Any updates? Was 56mm the correct measurement?
I checked and it doesn’t seem like 56 mm would fit inside the motegi cap since the actual center part on the mr118 caps are pretty small. I think we’d need to get blank center caps and then put the sticker on those.. haven’t really found good solution yet.
I'll be replacing the Motegi emblem on the Motegi caps with the Subaru logo emblem . . .
I have two extra sets of these domed 3D emblems. These were made to fit the Motegi MR118 caps. One set is with a silver Subaru logo over black background and the other set is a silver Subaru logo over dark blue background. $11 for each set shipped (what I paid).
Those are just stickers not caps?
1 - 10 of 10 Posts
