Code came and went many times. Put snapon scanner on, but showed no codes but anyti skid and Abs lites on . This happened last winter and this winter, but NOT in summer. But scanner in 4 Graft mode showing all four wheels at same time and it showed No graft for left rear wheel. Replaced left rear wheel speed sensor and all 4 grafts match when driving and code SS is gone and lights are gone. Still funny only bothered in winter
03 H6 OBW & 06 WRX Sportwagon
more details on vehicle please - what code, etc.
some Subaru ABS systems are very sensitive to low voltage, maybe battery or batt cable or alternator issues?
check voltage, look for slipping alt belt, etc.
Odometer reading disappeared and it shows SS on right side of odometer. Antiskid and and ABS lights are on. Cruise No work. I put Snap on scanner on and it only showed that the lights I mentioned were on. But scanner showed no codes. Put scanner in prod 4 scanner grafts at same time, took for drive and No graft for left rear wheel. So replaced lr wheel speed sensor. Now have 4 matching grafts and lights are now out. Why it only bothered last winter and this winter, and not all summer I don't know. Or why scanner showed showed no codes. Only showed problem in scanner Graph.Good luck
Outback 2011 3.6R Premium
This is a multiple post can admin please merge of remove @administrator
