Hey all,
I'm sure this question has been asked but I could not find it and I am not a forum wizard like some of you.
I just got a 2020 outback and plan to take it on some light dirt roads. I know a stock outback is no rock crawler, but there is a real chance of some light bottoming out with the outbacks low approach angle. I was planning on getting subaru's Steel engine gaurd and rear dif gaurd.
Part# E515SAN010
My question is, is it worth it? I know there are lots of third party amazing skid plates out there. But i don't plan on lifting this car and slapping K02s on it. I just need protection if I hit a spot that is a little steep or deap. Do you think the OEM steel guard will cut it? Or do I need to shell out the big bucks for a real skid plate?
Looking at all the options and coming to terms with that I will never lift the car I dont want to do one of those big 3rd party plates. The outback nose is already long and losing an inch on the front is a big deal. I chose to just get the OEM aluminum guard. It adds a little piece of mind while keeping you honest about what the car is realistically capable of.
I crunched the numbers and in order to make a new subaru into a off road beast you would be better off getting some 1995-2010 true offloaded that you can beat up and would be more capable.
The aluminum front guard is enough to take a scrape or plow some snow just fine.
Thanks! I don't have the turbo so I was going to get the steel plate... Any idea what kind of a hit on MPG that would take? I think I'm just going to do it for peace of mind. I feel like its probably a similar weight as a hitch so maybe it would shave ~2mpg off.
You think a hitch would take off 2mpg? I have no idea but that seems like a lot. The hitch or steel plate don't weigh that much. I can't imagine if a driver gained 20-40 lbs that the mpg would take that kind of a hit. Haha.
The oem steel and aluminum guards are pretty much the same shape as the plastic one and are flush to the body work. So aerodynamics won't change. Just a bit of weight. I don't think you will see a difference. But I'm no pro.
Thank you both! @Ralph Thornton Thats exactly my plan too. I was hoping to sell the yokohomas that come stock but i dunno if thats even worth it... From what I've heard the trails I need to get on are fine for the suby but I'll need to take it slow. Maybe I'll put the tires on craigs list for a reasonable price and see if I get any takers.
Installed the front Subaru metal Underguard/Skid Plate on the 2020 Outback, 2.5 engine, and thought it turned out ok. Am not saying it is a boulder basher but am guessing it’s 3/16ths steel. It was not super easy to install mainly because it’s heavy but once you get it up in place it stays there...
I added the Rear Differential Underguard and found it it be a fairly easy job. The instructions show illustrations but give no text. Am not saying it would withstand major abuse but it does provide some protection. I wanted it to protect from flying rocks on the gravel roads I drive on.
www.subaruoutback.org
Related Threads
Subaru Outback Forums
1.9M posts
188.8K members
Since 2003
Welcome to the Subaru Outback Owners Forum, we have tons of information about your Subaru Outback, from a Subaru Outback Wiki to customer reviews.
