1 - 20 of 25 Posts
2012 Outback Limited, 2.5i
So I have a 12 ob limited that I bought new 5 months ago. Today my wife calls to tell me that the sunroof will go up and down but not back and forth. Not sure what the problem is but it's going invtbe shop on Thursday. Anyone else have an issue?
Sent from my SCH-I535 using AutoGuide App
Mine the up down switch stopped working and the open close is not one touch and does the tip up too. I need to get back to the dealer. Subaru was sorting out a fix. The switch apperently has some logic to it and ut gets fouled up.
2013 Outback 3.6 Limited
So glad I ordered mine without sunroof. I had an older car that always leaked from Sunroof, total pain. Had previous Sunroof in previous Subaru's with no issues ...but just didn't want to take any chances. One less thing that could go wrong.
2012 Cypress Green 2.5i Premium CVT w/AWP & Moonroof
My sunroof broke on my 2012 model within the first couple months. It would get stuck in the track when sliding open and I almost could not get it closed one time. Dealer said track was bent (probably from the factory) and they had to replace the whole unit. It took them an entire day to install it. No problems since then but I am paranoid every time I open it. Good luck.
Fresh Out of Outbacks!
I noticed in our sunroof the other day when raising it up and down it was chattering and not moving smoothly. I tried it again last night and it was fine. Not sure what is going on.
The body flexes a bit- so the sunroof might move perfectly when you're on level ground, and it might bind a bit when you're not. If the car is in motion, vibrations will usually let it slide more easily than when the car is at rest.
Whatever floats your boat. We won't even consider a car without
a moonroof (or a ragtop ;-). Have owned nothing else in the past
25 years, 750k miles. Zero leaks, one warranty repair -- $0.00.
Switched to Soobie because Mazda6 was no longer available with
manual tranny & moonroof. Next time, will switch to something
else -- unless Soobie decides to offer MT with MR once again.
...different strokes,
Looby
Bought a 2012 Premium 6MT with sunroof so there is hope for Subaru.
Looby
Discussion Starter · #10 ·
UPDATE: Dealer called me today to tell me that the sunroof was just out of alignment and its fixed. While this doesn't excite me, I am happy knowing it just needed to be adjusted.
Not available for 2013 -- at least not in the USofA.
Looby
2012 3.6R OB Limited - Moonroof - Ice Silver
Sunroof is one of the main reasons I purchased an extended warranty. They can be well over $1000 to replace. A buddy had an 06 legacy wagon with the panoramic moonroof that needed to be replaced to the tune of $1400.
2013 Subaru Outback Premium 2.5i All-Weather+Moonroof Venetian Red Pearl W/ Ivory Coth
We love our sunroof. Hopefully we dont have any issues. I hear of so many people that dont use them, but have them anyways. We use ours quite a bit and we dont even live in a beautiful climate area here in hoosierland
Just so everyone knows. The sun roof switches have logic in them they learn the positions of the sun roof ie program. In some cases the switch might loose its logic when this happens the tilt button becomes inactive and the open close button will operate the sun roof and tip up and tip down. There is a learning mode where you open the sun roof hold the switch for a second then close it multiple presses required on the switch - then you continue pressing to it tips up then one more press where it will tip up slightly more then you close it. What is happening is the switch is re learning the stop points or positions. Mine did this recently and the Subaru tech did this learning thing in about 1 minute and now its fine.
He said that in some cases dead battery or software upgrade to the cars that the switch will loose its logic and need to relearn the positioning of the sunroof.
So if you have a case where the tilt up and down becomes inactive and the single press open and close stops working - don't assume the sunroof is broken or stuck - the switch for whatever reason has lost its logic on the stop points and positioning of the sun roof and needs to relearn them.
'15 STi and '13 GTI
The car was in motion both times.
'15 STi and '13 GTI
Huh... In the past 25 years, between my parents and my wife and I, we've had 11 cars from 4 different manufacturers. All had factory sunroofs and we've never had to replace one.
Iainb - the panaramma split roofs have seen expensive repairs they are far more complex than the basic sliding sun roof. Also most people never know if their sun roof was subjected to someone trying to force it open and that is why its broken etc.
People can have any fear they want when it comes to cars if their fear is so great that every little issue is a game ender they should simply dump their car and get a bicycle and start taking the bus.
'15 STi and '13 GTI
How is any of this relevant? No one in this thread has a split panoramic sunroof.
At what point did I attack or criticize the poster I quoted for their opinion? If someone can say that they had a friend who had a bad sunroof in a car I can certainly reply that I've had 11 cars that have not. :rolleyes:
I hear of so many people that dont use them ...
We don't often open it, but we use it every day -- for the light.
Open or closed, we won't buy a cage without a glass roof.
^ -- thats why I wrote what I wrote
And yes the standard old slider vs more complex is not even a issue with the new cars
1 - 20 of 25 Posts
