1 - 8 of 8 Posts
Can someone tell me which part numbers and manufactures have a rear sway bar that will fit a 2008 outback 3.0? I think a 19mm will be fine. I would like to go with Subaru online parts since they are cheaper.
White Line. Just look up the size you want for your OB. There are distributors in the US. Just use the dealer locator.
Fresh Out of Outbacks!
I put ralliteks on mine, love the way they work.
At one point rallitek claimed to be the only manufacturer making one piece forged bars (vs welding on the ends) but I don't know if this is still true.
The body doesn't roll as much in a fast curve or sharp turn. Gives a much more confident feeling. Crosswinds aren't noticeable.
The downside is that when on bad dirt roads or completely off road, the car is a lot stiffer and you get rocked side-to-side a bit more.
But I did the math... I'm driving about 200-250 miles off road each year, and about 12,000 on the highway. Totally worth it for my situation.
Wish I could tell you- despite living in Pennsylvania & frequently traveling to the Boston area, I've managed to miss almost every snow since I bought the car 2 years ago.
Theoretically, it should have the effect of increasing the pressure (and therefore grip) of the outside wheel relative to the inside wheel in a turn. This only lasts until that tire loses grip and starts to slide. Once the slide starts, I expect more fishtailing than on the stock setup. I actually prefer this, as I learned to drive in a RWD car with lots of oversteer, so countersteer recovery is old hat.
I do drive it on poor dirt roads & soft sand, and the above has held true in those circumstances. In short, I feel like it's easier to make the car slide, but the slide is much more predictable & controllable than it was before I did the mod.
I hope that answers your question.
well let me ask this:
Since i cannot find a rear sway bar for a 2008 outback at Subaru online, what will match up?
2010 outback? (i wouldnt think so), one from a legacy maybe?
I do not need anything heavy duty just want a stiffer ride. I am thinking the 19mm will be sufficient.
1 - 8 of 8 Posts
