1 - 7 of 7 Posts
White 2015 Premium ADF 2" lift. Previously, 2013 Pzev Ice metallic silver.
Installed the switchback drl/ turn signal leds. Standing on the porch last night, observed the drls flashing on for a couple of seconds every hour or so. WTH?
2015 3.6R
Mine will turn on sometimes for no reason but don't flicker. I think it has something to do with voltage. Hasn't been an issue and I've had mine in for some time now.
It's annoying. It's also stated coming on longer sometimes. I've taken to disconnecting it overnight. Think I may add an inline switch.
I put in a switch so I won't ever have the surprise of a dead battery. Shut the car off, throw the switch. Beats taking the fuse out....
Sure wish I knew what's causing a switched circuit to randomly turn on!
2015 3.6R
How did you add the switch? Where did you run it through?
2015 3.6R
Mine don't flicker but will still come on randomly from time to time with car turned off. Has not been an issue to date and I've had them in for well over a year now. Never looked into cause but since I've gotten a better battery I haven't noticed the issue.
1 - 7 of 7 Posts
