1 - 19 of 19 Posts
Hello,
My tail lights, marker lights, and license plate lights are not working. Brake lights, signals, headlights, hazards all work fine. I've replaced both the fuses and that hasn't fixed the problem. Diagram shows a Tail and Illumination relay and I thought it might be that but the illumination on the dash works fine. Parking light turns on all of these lights so it's not a bulb. Any suggestions?
Check the bulbs/sockets. After that, I'd suspect a broken wire in the harness, where it passes from the body of the car/lift gate.
You should fill out a signature, so we know what year your car is.
If the parking light switch (on top of the steering column) turns on all the exterior clearance and tail lights, then most of the wiring is apparently okay. The Parking Light switch, and the regular light switch, generally use the same wires to send power to the bulbs.
Model/year would indeed be helpful.
Thanks.
If the dash lights (instrument panel, radio and heater controls etc) turn on when the headlight switch is turned On, but the clearance and tail lights do not, that leaves the Parking Switch (on top of the steering column).
There have been cases where the switch contacts have become corroded and don't conduct. When the Parking Switch is turned on (separate from the headlight switch) a different set of contacts is used, and the external clearance and tail lights work. But when the Parking Switch is in the Off position, the external clearance and tail lights don't work.
In the following section of the wiring diagram, when the Parking Switch (upper left) is in the OFF position, power comes from FB-2, fuse 7, to "B" on the switch, but goes no further. At the same time, the Tail & Illumination Relay provides 12 V to "T" of the Switch, when the main ignition switch (key) is in the ON (IGN) position.
"P" of the Switch goes to FB-3, which connects to the tail, clearance and license plate lights circuit.
When the Switch is in the ON position, the exterior lights work, so that confirms all the wiring from "P" onwards through FB-3.
Furthermore, as was noted, the dash lights do work when the headlight switch is turned on. The dash lights are supplied by the relay. In the diagram, only some lights are shown, powered from FB-26, fuse 12.
So if the dash lights work, the relay is working.
That leaves the Parking Switch, or wiring specific to it, as a probably cause.
Have to check continuity through the Switch. I'd start by pulling fuse #5 and fuse #12, and with the ignition Off and the Parking Switch at Off, check for continuity. If the switch is good, there should be continuity between one side of fuse #5 and one side of fuse 12. (There's four possible combinations of test connections, but that shouldn't take much time.)
Alternatively, it might be necessary to remove the covers from the steering column to get to connector B69 (4 pins) that connects to the Switch.
2002 - your wiring running from the rear head liner to the rear hatch can break over time due to the opening and closing of the hatch. Very common issue easily fixed if you know how to do a little soldering and replacement of old broken wires.
The OP said that all the lights work if the Parking light switch (the one on the steering column) is used to turn the clearance and tail lights on, rather than the headlight (stalk) switch. That suggests the wiring to the lights is good. Moreover, unless a broken wire going to the rear hatch is shorted to ground, the broken wire would affect only the lights on the hatch, not the other clearance and tail lights. And if it were shorted to ground, it would blow the fuse (#5), so the lights would not work regardless of which switch is used.
I don't disagree with the idea that wires going to the rear hatch can be broken, but in this case, the combined symptoms don't seem to apply, unless the description of the problem is incorrect.
Discussion Starter #8
Plain OM, I am looking for a replacement parking light switch. I've checked autozone.com and rockauto.com. Neither have a replacement part of that name. Would it be listed under a different name?
No doubt but shorted wires do all kinds of goofy stuff down stream. Still should be eliminated from the check list.
Have you verified that the switch itself is bad?
Probably dealer only for a new one, but perhaps consider a used one from recycling yard. (I haven't worked on one of these switches, and wonder if it can be opened to clean/refurbish the contacts, if that's the problem.)
See this page for a typical diagram and part numbers: http://opposedforces.com/parts/legacy/us_b12/type_21/electronic/switch_combination/illustration_1/
If the switch isn't yet confirmed as the problem, might as well consider checking the wires going to the rear hatch as well -- lift the flexible covers and examine the wires inside.
Discussion Starter #11
I haven't been able to test the switch. If it was cheap enough I was going to just switch it out. Anyway, new development. After running the all those lights by flipping the parking light switch as a temporary fix now they don't turn on even with the parking light switch. It seems as if I read this in another forum but didn't see a resolution to it there....
Will update when fixed.
Discussion Starter #12
For anyone who has been having a similar problem I am posting my resolution. I finally was able to take apart the steering wheel yesterday and get to the parking light switch. I found that the orange wire in that switch had broken off at the soldering. I decided that the parking light switch was not essential so I used a dolphin clip to connect the orange wire to the brown wire. I used another dolphin clip to cap off the white wire. This fixed the problem. Lights are working fine now.
2005 2.5I outback
I have had the same issue with my 05' outback. There were contacts on the switch where the wires are soldered to that came apart. You need to pull the steering column off to get to it. They can either be soldered or I am myself looking to bypass the switch. Plain OM do you have a wire diagram of the plug that attaches to the switch unit that differentiates which wires are which so I can totally have the system bypass that switch?
2005 2.5I outback
Benderitaliano, there is an aftermkt sub I dealer in Boulder Co that sold me a used switch for $10. Not sure if they mail parts but it's worth a try. It's called super Rupair. 303-442-6508. It's worth a try. It's seems there are lots of issues w the parking switch. I'm looking for a wiring diagram after the switch and after the fuse, so basically from the final fuse to the actual rear lights. If anyone has this can us post please?
98 Legacy no tail lights
I have replaces the hole wire harness behind the steering wheel because me parking light switch was broke and i got that all on and all the wires back together and still no tail lights. I also have checked all the fuses and also all of the bulbs help im stuck i want my Subaru back lol
Welcome.
To start . . .
How long have you had the car, and how long have you had this problem?
Only the tail lights don't work, or all the exterior tail and clearance lights?
Which fuses did you check, and how did you check them?
There's two ways to turn on the tail and clearance lights -- the parking light switch on top of the steering column, or the headlight switch when the key is at the ON position. Do both not work?
When the key is at ON, and the headlight switch is used to turn on the tail and clearance lights, does the interior, dashboard controls lighting come on?
Is the parking light switch on the steering column connected? Did you test or replace it? If tested, how?
I've attached a wiring diagram that should apply to your 98.
This sounds like a similar issue I am having with my outback 2008. How do I know which wire in the rubber boot belongs to the license plate light? Also my reverse lights are out. Dash lights, brake lights, headlights, blinkers, rear wiper, heater, all work.
Hello all, I am new to this forum and I know it has been a while since this was last discussed on this thread but it seems to be the most relevant to my situation.
First off, I have a 2002 outback that I have had for 5 years or so.
I will try to list all issues in sequential order in hope it will make sense to anyone.
About a month ago I was having an issue with my passanger headlight. (plain light no hid or any aftermarket light). It seemed like I was having a short because it would go out, I would tap the lens and it would come back on. I replaced the pig tail and thought my woes where resolved because I had a head light agin, next day same issue purchased a new light housing and replaced it the next day and at the end of my shift the battery was dead again.
Unplug that light no dead battery after a jump and running it for an hour then letting it sit over night.
The next day go to work to find out I have no running lights/ clearance lights/parking lights. That evening when I left work my battery was dead. Jumped the car all was fine drove home but still no running lights.
This is what I do have.
1) head lights and hi beams.
When i plug in the passenger side I have both but generally only driverside.
2) blinkers front and back
3) break lights
4) reverse lights
5) Interior lights
6) dash lights
7) working radio
8) all multi switch functions work
What I do not have
1) running lights front or back weather or not the switch is pushed on the steering column.
2) i have checked my parking light switch with a new 1 and no changes.
3) i keep blowing fuse 5 when i plug in the connector plug for the parking switch on both new and old switches.
I have had all lights tested and fuses tested. I have a test light to check the fuses.
All bulbs have been checked for corrosion and moisture.
I do hope this was not to much at once.
1 - 19 of 19 Posts
