I had a company tiddy up my wiring for a 32" OPT7 LED roof mounted lightbar.
Right now it is just tapped the current from the inside fusebox only when ignition is on, but I am getting tired of manually reaching down to the Subaru OEM fog light switch to activate it.
I'd like that source moved to the high beam so that way I can just use the high beam stalk on my steering wheel to turn LED on/off.
Is there a high beam source on that interior fusebox, or will I have to run a wire out to the engine compartment and tap there?
Thxs.
Thxs.
