Has anyone tried tapping into their main fuse box? I need a 12V output that is NOT active when the ignition is off. (E.g. seat heater, power windows,...). I am trying to avoid going through the firewall and using the instrument panel fuses.
P.S. This is to power a wireless receiver that controls my ditch lights. It's currently powered directly from the battery and I am worried it might drain too much over night.
You should be able to piggyback on a circuit using an add-a-fuse. Definitely use something that’s not critical, but I don’t foresee you having any trouble with this.
2020 Outback Limited 2.5i
Could you just pull the power from the accessory socket in the glove box? It's only hot when the car is on. I use it to power a dash cam.
