  • Hello Everyone! Let us know what you would spend a $50 Amazon gift card on, HERE For a chance to win a $50 Amazon Gift Card!
  • Submissions are now being taken for JUNE OUTBACK OF THE MONTH
21 - 24 of 24 Posts
Discussion Starter · #21 ·
Yup, I removed the ground straps in the engine bay to check them and they were all clean, sprayed them with carb cleaner to degrease, wiped down and scuffed, then reattached.
This ground cable should reach the alt bolt, perhaps this may be a more effective place to reinforce the grounding. I'll play around with it tomorrow! :)
Gotcha, that's kinda what I was looking for. Thanks for the input. If it happens with everyone, then I guess I can't do much about it aside from getting a custom higher output alternator, which isn't feasible for this car.
I'm not sure if mine is particularly weak, or if it's just the nature of the beast, but it happens with individual turn signals too. LED is a good idea, but I wish I wouldn't have to replace every single bulb in the rear of my car to try to alleviate this.
Looks like 90A is the stock alternator output, is there a direct-fit higher-amp application, like a 100A from an H6? (won't physically fit, right?) Or a later model H4 that used 100A? Maybe my aftermarket alternator just sucks? If I went with a Bosch or Denso replacement, are those common aftermarket alternators for these?
My '05 Legacy did not have this issue, I suppose this was fixed in '05 with the new generation.
I have a 2000 Outback sedan and mine is doing the same thing.
I just read some threads on this forum from back in '04, it seems the dimming lights problem was normal on these cars even when new.
Since then:
Has anyone ever fixed this issue? Are there members here that don't have their headlights dim when they hit the brake pedal? Every bulb, interior and exterior, on my '01 dims when I hit the brakes, or even use my turn signals.
My OB has a brand new battery, and the alternator was replaced about a year ago. Clean terminals, all of the grounds I've seen look fine and have been unbolted/reattached.
If there is an alternator available that is higher output, or has a better voltage regulator that will solve this problem, I am all ears.
Back in '04 a Canadian member found that all of the new Legacy/Outback models on his dealer's lot exhibited this same problem. I am hoping that since then, a better alternator or a homebrew fix has been developed to remedy this. When tapping the gas pedal, all of the lights brighten, so it is obviously an issue with the charging system being inadequate at idle by design.
Discuss!
I had a problem with my 04 that in the winter time my car wouldn't want to start using a charger and it didn't start even though the battery was good only way I could get it to start was with with a jump from a BMW in my other car
I did the whole cleaning round bits and I actually added grounds didn't really help
I finally found out what it was it was the terminal negative terminal on a battery cable bad crimp on the terminal I bought a couple new ones from Amazon brass terminals replaced it then noticed no more problems at all starting the car and then also the lights look much brighter than before so that might help you out
21 - 24 of 24 Posts
