I have the P0171 and have isolated it to an exhaust leak at the front exhaust directly off the manifold. I understand there's flex pipe under the heat shields that can crack, which seems to be my case. Anyway, I was wondering if anyone had any thoughts/experience with the Walker 52368 front exhaust pipe? It's listed at $120 and seems easy enough to DIY.
My '05 is a federal emissions. The rest of the exhaust is solid, just need to address this. Thanks in advance.
Its best to just get one that lists for your vehicle. If it indeed is leaking from the flex joint, a exhaust shop should be able to chop it out and weld in a new one for $60 or so. Not sure if you are in an area with essential workers only. Just specify you want your heat shield back on lol.
To answer your question, yes: the USDM 05 Impreza (and Foz) also fit the 2005 Legacy/Outback (Federal emissions). 06 is different and Cali is different.
The 2005 system does not have a flex section in the front/pre-cat pipe. That's on the turbo manifolds (crossover pipe) or the 06+ cat manifold.
The Walker is decent, but at least you get a warranty. I'd avoid the cheap, stainless headers. Thin stainless tends to crack and you're right back to square one.
Thanks very much for this! I guess I'm just going to have remove my front pipe and see how bad things are and if it can be welded up. If you had to pick a replacement, which would you choose? OEM?
If the plan is to keep the Subie for a longer time get the OEM front pipe. Walker is more affordable but won't last as long as OEM. Local muffler shop should be able to cut the old flex and weld in a new one. Make sure there is enough clearance for them to do the job right. Had a bad experience with the local Meineke muffler shop that half-assed welded the flex section and used putty to seal the exhaust area they could not weld. The putty only lasted half a day. Very disappointed that they were not upfront with their inability to do a complete job. I strongly recommend going with a new flex front pipe and avoiding Meineke. Attached pic is the inspection mirror above the half-assed welding. Ignore the rusty axle shaft.
Wow, that's messed up. I talked to a local shop Friday and we're going to see about getting this sorted, along with some other work. But yeah, I'll look at either OEM or a proper fix of what I have - I try to stay away from those chains at all costs.
walker stuf fis junky, lasts from 1.5 to 3 years at best. Its a good exhaust to place on a vehicle directly before dumping/selloing it, but not a brand to put on any car you want to keep and drive for more than.a year.
Related Threads
Subaru Outback Forums
1.9M posts
188.3K members
Since 2003
Welcome to the Subaru Outback Owners Forum, we have tons of information about your Subaru Outback, from a Subaru Outback Wiki to customer reviews.
