1 - 8 of 8 Posts
1999 Subaru Legacy Outback 2.5 H4 30th anaversity model
Just installed water pump and all idles ect. Put the belt on and I have a problem getting the drivers side intake cam lined up properly. When I start out all the line are where they should be. I rotate the crank 2 times and check all the markings and all are good except the drivers side intake can then seems to be off. Any ideas would be greatly appreciated.
RWT
They were off. I am going to give it a rest. I have had it apart too many times.
RWT
1997 Outback 2.5 AT
here's a trick.
when the belt is loose you can set the pulley just a little bit past the timing mark, and when the belt has tension applied, it will be pulled back "in time" and line up on the mark.
03 H6 OBW & 06 WRX Sportwagon
also, find the tooth count for your engine online, good triple check.
1. camera angles could be a tad off
2. the tensioner may not be pulled and operating
3. if the belt hasn't been rotated yet then the tension isn't fully dispersed
4. move that crank counterclockwise a millimeter and the cam is going to close the distance even more.
5. combine all of that and it may mitigate what is currently less than a half a tooth difference (#1 notwithstanding)
It may be fine?
On my older 93 DOHC Dodge Stealth I had to move the crank timing mark back by 2 (as indicated by the factory manual). Then once the belts and all were reinstalled and you pulled the auto-tensioner, it then pulled everything right into line as expected.
1 - 8 of 8 Posts
