Getting ready to take the car in for a timing belt replacement and would like to have it done right so the engine doesn't need to be opened for as long as possible. I am looking at the Gates Complete Racing Timing Belt Kit (EXTREME PSI : Your #1 Source for In Stock Performance Parts). I have heard that it is good to use an STI water pump for increased flow. It sounds like this kit should have the STI water pump since it is listed for the STI as well. Other than the kit(pulleys, tensioner, belt and water pump) I just need the cam and crank seals, correct?
Also, what should I expect to pay for valve clearance inspection?
