I have seen this overlooked by even seasoned technicians. I see tons of posts about overheating problems and even some misdiagnosed head gaskets. Unobstructed heater core circuit flow is essential to the proper operation of the cooling system. I have created a drawing to illustrate why it is essential.
For the thermostat to open, it needs to have coolant with a temperature above the opening threshold at the sensing bulb shown on the lower left of the drawing. With the exception of an insignificant amount of coolant that flows through the throttle body heater circuit, all of the coolant flowing to the thermostat sensing bulb must come through the heater core.
A restricted heater core can block high temperature coolant from reaching the thermostat bulb. Without that high temperature coolant reaching the bulb, the thermostat will remain closed regardless of the coolant temperature in the engine. Even a partial restriction that allows some flow but is cooled significantly when passing through heater core will affect the thermostat operation due to it seeing a lower temperature at the thermostat than the than the actual engine temperature.
One problem with a blocked heater core is that it presents itself with the same symptom that you may see with a head gasket that is leaking combustion to the cooling system. You will have overheating with poor cabin heater performance.
My advice when you run into a "tough-to-pin-down" overheat problem, is to always bypass the heater core to see if it eliminates the overheat condition.
