1 - 13 of 13 Posts
2001 Forester, 1997 Legacy wagon, 2.2
Did I say seven threads? It is now more than seven !
Thanks to all that posted threads on Torque Bind !!!!!!!!!!!!!!!
I figured a grouping of useful threads in one thread will expedite the next beginner's search of forums. ( I hope a mod will move it if this is incorrect placement. ) thanks.
I collected links from the threads I found.
Some are awesome! Some may have only one relevant post. Some are related in a general or secondary way, like ATF changing.
Here are the threads I found helpful.
Note, a few are not from this forum.
Some are for Subaru Forester, for example.
begin
Can somebody please thoroughly describe "torque bind"?
www.subaruoutback.org/forums/111-gen-1-1995-1999/45164-can-somebody-please-thoroughly-describe-torque-bind.html
1996 Auto Transmission Problems, Torque Bind, and More
www.subaruoutback.org/forums/66-problems-maintenance/35386-1996-auto-transmission-problems-torque-bind-more.html
Torque bind problem fixed. 1992 Legacy AWD non turbo automatic
Torque bind problem fixed - 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX - Ultimate Subaru Message Board
SOLVED: Slow speed (e.g. parking) bind normal?
('03-'05) Slow speed (e.g. parking) drag normal? - Subaru Forester Owners Forum
Changing Automatic Transmission Fluid (is easy) 41 pages
www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/5843-changing-automatic-transmission-fluid-easy.html
('03-'05 Forester) torque bind??? What should I do
('03-'05) torque bind??? What should I do - Subaru Forester Owners Forum
4eat tail section rebuild without removing transmission
www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/27878-4eat-tail-section-rebuild-without-removing-transmission.html
......end
Bonus:
How To: Read transmission codes ( 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX )
How To: Read transmission codes - 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX - Ultimate Subaru Message Board
Thanks Again !!!!!!! You guys are great !!!!!!!!!
Discussion Starter #2 (Edited)
Here are more helpful threads related to Torque Bind. They are a few years old. Maybe another newbie is searching for info.
Thanks again for all the great help !!
shuddering issues. 98 OBW
ms/111-gen-1-1995-1999/286498-shuddering-issues-98-obw.html
torque bind idea/question
www.subaruoutback.org/forums/66-problems-maintenance/48754-torque-bind-idea-question.html
diagnosing 4EAT clutch pack or duty-c solenoid (has some tests you can do)
www.subaruoutback.org/forums/66-problems-maintenance/59962-diagnosing-4eat-clutch-pack-duty-c-solenoid.html
Dealer quote for transfer clutch duty solenoid (has diagnostic info)
www.subaruoutback.org/forums/111-gen-1-1995-1999/82218-dealer-quote-transfer-clutch-duty-solenoid.html
Automatic Transmission Jumping/Dragging/
www.subaruoutback.org/forums/66-problems-maintenance/54168-automatic-transmission-jumping-dragging-thudding.html#post533673
DIY 5EAT ATF Flush
hot link failed. Please try this url instead:
legacygt.com/forums/showthread.php/diy-5eat-atf-flush-197248.html?
4 More:
How can a center differential on a subaru go out and ways to fix it? https://mnsubaru.com/threads/how-can-a-center-differential-on-a-subaru-go-out-and-ways-to-fix-it.31548/
1997 Subaru Outback, rear tires drag when making sharp turns, bad viscous coupling??
www.subaruoutback.org/forums/66-problems-maintenance/9476-1997-subaru-outback-rear-tires-drag-when-making-sharp-turns-bad-viscous-coupling.html
Here's a good one:
Subaru All Wheel Drive System Failures & Repair
mdhmotors.com/subaru-all-wheel-drive-system-failures-repair/
Tire circumference has me worried
http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/21658-tire-circumference-has-me-worried.html
Discussion Starter #8
Another:
Thanks simple OM
Great info:
North American Subaru Impreza Owners Club
Torque Bind
forums.nasioc.com/forums/showthread.php?t=2594381
More:
AWD vs FWD question, 97 OBLW
www .subaruoutback.org/forums/66-problems-maintenance/334969-awd-vs-fwd-question-97-oblw.html
Viscous Coupler in Auto or Manual Trans?
www.subaruoutback.org/forums/66-problems-maintenance/335945-viscous-coupler-auto-manual-trans.html
Transmission Fluid mystery.
www.subaruoutback.org/forums/66-problems-maintenance/335649-transmission-fluid-mystery.html
Discussion Starter #10
Second time around, I settled for the easy fix as some others have done.
I simply removed the rear part of drive shaft. Now the car (96 Impreza) is a Front Wheel Drive car.
I have read that some models were originally produced as FWD cars (without the rear shaft) but did have the connectors in place for AWD.
Loss of performance is not much of an issue in my case. Driving around town under 50 mph is about all I ever do. So far so good.
oh well,...now you got a fixed up forester with AWD for when the going gets tough in paradise.
Discussion Starter #13
1 - 13 of 13 Posts
