I'm hoping to tow a Spec3 racecar (spec weight w/ driver 2900lbs) on an aluminum double axle trailer with brakes (1300 lbs) with a 2005-2009 Outback XT manual. So, I'm looking at 4200lbs loaded trailer weight with a corresponding tongue weight of roughly 420lbs (10%).
The US towing specs are 2700lbs gross trailer weight and 200lbs tongue. Apparently, European models (self-leveling suspension?) are rated at nearly 4000lbs though I haven't found tongue weight.
I figure I can stiffen up the suspension and get that at least as good as Euro spec with King Springs, maybe stiffer struts of some kind, and upgraded swaybars. I'm not sure how to increase max tongue weight, though.
Long story short, any thoughts on how to increase the max tongue weight? What's the weak link?
I've done tons of searching on this forum, legacygt and subaruforester etc. with no luck. I'm aware that this might be dangerous. Please don't respond with safety first, buy a truck, think of the children etc. Thanks for any responses.
