I just bought a '13 Prem OB and am setting up a separate set of winter tires. I am considering buying the Schrader 3300 315 mhz EZ-Sensors so that I can have them programmed with the original ids from the factory wheels.. so I can swap as I see fit with no trips to anyone to reset anything.
Why is this not the best way to go ? Amazon has the sensors for $47.40 each. Sure I can get the non programmable ones for a little less.. $42.99 at AdvanceAuto before applying the A124 coupon to get $40 off the set.. So it would be about $50 cheaper to get the non programmable Air Aware 28203 sensors.
Any opinions ?
Also.. tirerack steel 16" rims (not ordered yet) with 215/70/16 Blizzak DMV1 from costco ($468 after instant rebate) is what I am going to mount up. I assume tirerack knows the appropriate 48mm offfset and what I order will be that. I have seen folks selling used rims with 55 offsets and I have thought I can't go a different offset. Is 7 mm a killer on the 4th gen OB?
Appreciate anyone's opinions.
Any opinions ?
