Does yours have an electronic throttle body or is it cable driven? Did you check to make sure the pins on the sensor and harness are not bent and making a solid connection?
If its cable, and you have a scan tool that reads data, the closed position of the TPS is 0.0%/0.50 volts. The percentage and voltage will increase as the throttle is opened up to 100%/4.5 volts.
If its the electronic throttle body, make sure it is plugged in secure, start the car and let it idle for a few minutes to learn.
