1 - 12 of 12 Posts
2003 Outback 2.5L
I have an 2003 Outback automatic 4 cyl. It has developed a whine when on the gas. As soon as you let off it goes away. It sounds like a planetary gear noise. Similar to what an old granny low 4 speed would sound like. I did a drain and fill on the trans about 4 or 5 weeks ago. Since then my wife has been driving it most the time and she insist that she hasn't noticed a difference in it, but since I last drove it, it seams a lot noisier. I checked the trans and diff fluid level. Both are full, the trans is a hair over full, not much. The noise is definitely coming from the front trans area. Any thoughts appreciated. Thx Stacy
00 OB 07 OBXT
so it was making the noise before the drain and fill ?
how many miles on the car ?
you are checking the fluid hot, running [have to ask] ?
did you change the filter ?
you are positive it's coming from the the trans/diff and not the front of the motor [acc belts, ac, ps, water pump, timing belt or pulleys] ?
if it sounds like gear noise, i'd lean toward the diff. maybe try a drain and fill on the diff, see if that quiets it down.
'00OBW, '96&'94 Legacy - all rusted RIP, current: 2016 Focus MT
Phase II 4eat does have a note about a particular whine which they say is the final reduction drive or something like that. Can lolok up details if needed.
2003 Outback 2.5L
Noise
It wasn't making it before, but I am relatively sure it wasn't making it right after either. The car has 98k miles on it. Checking fluid hot and level. The noise is directly under the shifter, obvious on/off throttle only with car in gear going forward. What is Phase II? A TSB or ??? Thx Stacy
4EAT=4 speed electronically (controlled) automatic transmission
phase II=4EAT style that started in 1999
TSB=technical service bulletin
The 4EAT phase II has a few 'characteristics' that were different than the previous gen; enough so that soob issued some notes about it. For yours I was thinking maybe #6 at the bottom:
A/T - Phase 2 4EAT Transmission Characteristics SOURCE: Subaru Tech Tips
TITLE: Phase 2 4EAT Transmission Characteristics
APPLIES TO: All models with 4EAT A/T
SERVICE TIP:
Phase 2 4EAT transmissions have been used in Subaru vehicles since the 1999 Model Year. They can most readily be identified by the external ATF oil filter located on the driver's side of the transmission case. Be advised that H6 equipped vehicles use a remotely located ATF oil filter. This filter is located in the Left front fender well area.
SOA and FHI have been investigating returned OEM transmissions for the last several years. We have been concentrating on units returned that were tested and found not to have any problem during the Dyno testing and disassembly inspection of the unit. Based on the paperwork comments, we have identified several different symptoms that would be considered normal operation for the unit. These characteristic symptoms will not be corrected by replacement of the unit or any components within the system.
It is important to understand that many decisions are made in the designing of the transmission. Items like fuel economy and emissions play a big part in the design. The design of the new 4EAT considerably increases the fuel economy and reduces the overall emissions of the vehicle. To accomplish this, the design incorporates fewer parts than its predecessor. This not only reduces the total friction, but also the overall weight of the unit. Because of this, the unit functions differently than the older 4EAT.
The purpose of this article is to make you aware of these characteristics, so when you receive a concern from a customer, it can be identified and explained to them quickly. Repairing of a vehicle starts with detailed questioning by the Service Adviser as to how, when, and where the condition occurs. Duplicating the how, when, and where by the technician should enable the concern to be identified. If the concern is similar to one listed below it should be explained to the customer it is a characteristic of this model and is not an indication of reliability or future concern. No repairs should be made to the vehicle. If you are unsure, we recommend you road test a 'like' vehicle. If both vehicles are similar, chances are it is a characteristic of the unit.
1. Delayed Engagement or Judder felt when shifting into Reverse or Drive.
Symptom When the driver shifts the select lever into reverse or drive and applies the accelerator too quickly delayed movement or a judder can be felt.
Mechanism It takes approximately 1.5 seconds to engage the internal clutch(s) after the select lever gear is chosen. If engine torque is increased before the clutch is fully engaged, the clutch will slip and make the judder feeling.
Recommendation To determine there is an internal problem with the unit, perform a 'TIME LAG TEST'. If the average is less than 1.5 seconds the unit is operating normally. If it is more than 1.5 seconds then an internal problem exists and repair/replacement should be preformed.
Explain to the customer the mechanism and function of the system and that it is not a defect in the unit. Also, recommend that the customer wait a second before applying the accelerator pedal.
2. Shock felt during light acceleration with the Lockup clutch applied.
Symptom When the driver tries to lightly accelerate the vehicle, when driving at a constant speed in 4th gear and the Lockup clutch is engaged, they may feel a slight shock through the body of the vehicle. Some customers may compare it to a Manual Transmission vehicle.
Mechanism When the accelerator is pressed lightly (approximately 20% or less), the lockup clutch is not released. This causes a direct coupling between the engine and the drive train of the vehicle. The slight shock is from the small clearances in the drive train gears, axle splines, etc. If the lockup clutch is not applied then, the shock is absorbed by the fluid coupling in the torque converter. Under certain conditions, this same shock can also be felt when activating the cruise control.
Recommendation Explain to the customer what they are feeling is a normal operation. Basically, the lockup clutch is kept on as much as possible to increase fuel economy of the vehicle. Increasing the engine load (driving on hills or pushing the accelerator more) will disengage the lockup clutch sooner.
We recommend you try duplicating this during some of your road testing (PDI) so you are familiar with the sensation. To do this, drive at a constant speed around 40 mph. Confirm that the lockup clutch is applied (use Select Monitor) and accelerate using light throttle. You will feel a slight shock throughout the body of the vehicle.
3. Click noise when transmission shifts from 2nd to 3rd.
Symptom When the transmission upshifts from 2nd to 3rd gear under light acceleration, a click can be heard from under the vehicle. Most customers will only notice this noise when they have the driver's window opened and are driving close to some structure that will reflect the noise back into the vehicle.
Mechanism The noise is created when the 2-4 brake is released during the 2nd to 3rd gear upshift. At this time, the clutch steel plates that are located into groves on the internal wall of transmission case shift creating the metallic click noise.
4. 2nd to 3rd shift flare after vehicle is parked.
Symptom After a vehicle is parked and it sits typically overnight, when it is started and the transmission upshifts into 3rd gear for the first time, the RPMs may flare slightly. This can be an intermittent condition depending on how the vehicle is positioned when parked, temperature of the transmission when parked, and ambient temperature.
Mechanism The shift flare occurs because the hydraulic circuit for high clutch in the transmission occasionally drains. When the transmission upshifts for the first time into 3rd gear, the hydraulic circuit must fill before it will apply the high clutch. The time needed to fill the circuit slightly delays the applying of the clutch causing the RPMs to rise slightly. The transmission will function normally for the rest of the driving cycle.
Recommendation Explain to the customer how and why they are experiencing this symptom. Also, make sure they understand it is not causing any damage or excessive wear to their transmission or vehicle.
5. Transmission delays downshifting during low to middle speed acceleration.
Symptom The driver wants to accelerate quickly and starts applying the throttle, but the transmission will not downshift to a lower gear ratio until almost full throttle.
Mechanism Basically, the logic (normal shift map) that controls gear selection is trying to keep the transmission in the highest gear possible for fuel economy. Subaru vehicles utilize a microcomputer (TCM) for accurate control of the gearshift timing, engine braking, lock-up clutch operation and other functions. It directly corresponds to throttle opening, vehicle speed, engine speed, and gear selector position. Various sensors and switches located on the vehicle feed information to the TCM. The TCM will make calculations based on all these inputs. The throttle position sensor provides electrical signals corresponding to the accelerator pedal position. The TCM not only can calculate how far the accelerator pedal has been depressed, but how fast it was depressed. In other words, the system detects and based on the driver's direct input from the accelerator pedal will shift the transmission.
Depending on the vehicle speed, if the accelerator pedal is slowly pushed down even to the floor, the TCM may not downshift the transmission. If, however, you quickly depress the accelerator pedal to the floor, it certainly will downshift into whatever the TCM determines to give the driver the best gear range for power and acceleration. This is a direct driver input and depending how far and fast the accelerator pedal is depressed will determine the vehicle power and acceleration. This gives the driver some ability to operate their vehicle based on power or economy.
Another item to consider is the internal operation of the transmission. In most cases, the TCM must turn off one clutch and apply another to change gears. If a clutch is turned on or off too soon it would cause a harsh shift. It also could cause premature wearing of the clutches. The logic was chosen to provide a balance of shift feel and wear characteristics. Fluid temperature is also a consideration. Cooler thicker fluid takes longer to move though a given passage than warmer thinner fluid.
Recommendation Explain to the customer the mechanism of the system.
6. High Frequency noise driving at 65-70mph.
Symptom The driver hears a high frequency noise (whine) between 65-70mph during a steady throttle or coasting. Noise can only be heard driving on a smooth flat road with the windows up and radio off.
Mechanism The noise is being generated by the reduction gear teeth in the rear of the transmission. The noise will only be heard on slight acceleration or coasting not both. Noise is not an indication of an internal problem and will not create any.
2003 Outback 2.5L
That sounds exactly right (I hope) except for the mph. Mine does it at any speed. Thanks for the info. Stacy
00 OB 07 OBXT
so did you change the filter ?
used the correct fluid ?
if so, maybe put some trans additive in there to quiet it down.
a drain and fill on the diff fluid might not be a bad idea, again, if it hasn't been done.
i'm going on the premise that there is a "new" noise and that since you did some work on the trans you are not being hypersensitive to any noise that's coming from there [we all do it].
2003 Outback 2.5L
I didn't change the filter, the book shows dextron 3. I did use just regular house trans fluid (advance auto parts). Maybe I will do an all synthetic Mobil 1 swap over and a filter and see what happens. The diff fluid looks as new, but I haven't serviced it since I bought the car 1 year ago at 60k. It is a new noise but not right after the service, maybe a few hundred miles later. Thx Stacy
00 OB 07 OBXT
personally i would change the filter.
not sure if this filter being partially clogged will cause something like this, doubt it as most filters have a bypass on them which just allows the fluid to go past without filtering it.
synthetic is good, it's also expensive. i just use name brand standard fluid and havn't had any issues with the trans. i'm always a bit leery about generic oils and fluids, i'm not sure if it's founded but i tend to shy away from the "really cheap stuff".
could be the same stuff in a different bottle but unless i can find out i'll stick with the majors or the proven performance stuff.
2003 Outback 2.5L
Discussion Starter · #10 ·
Well I drain and filled the fluid 3 times today with Mobil 1. I changed the filter, then I serviced the front diff. The drain plug had a huge amount of metal collected on the magnet. I suspect that the gear noise I am hearing is the front diff. I filled it with Mobil 1, but the car is no different. I will drive it till it quits and buy something else. I must say Subaru , at least this one, is a far cry from the quality I have received from my previous cars. I have had a Audi 90 that I never serviced anything but the engine oil for 217,000 miles and it never gave me a minutes problem. I will move on. Thx for the advise. Stacy
00 OB 07 OBXT
well you can count yourself lucky on that car you referenced.
most people do the same thing, nothing, and expect them to last forever. there is a maintenance schedule for a reason, it's a machine and needs to be monitored for potential minor issues as well as replenishing fluids that loose their ability to lubricate after repeated heat cycles and the shearing effect of normal operation.
doing nothing for 200k and having the machine give you no problems is not a sign of the quality of one product vs another, it's just luck. if you bought the one to the left of it on the lot you might have had a different experience.
some metal on the drain plug is normal wear and tear, like i said, the fluid loses it's ability to lubricate after awhile so you get increased wear.
you can try some gear oil additive like lucas or whatever you like to see if it helps. i've used it in worn rear ends and manual trans with some success.
2003 Outback 2.5L
Discussion Starter · #12 ·
The amount of material on the drain plug was enough to fill a childrens medicine cup, I will try some sort of patch, what have I got to lose. fyi: my wife drives a 98 3 series BMW with 207k on the odometer. I seem to be lucky with everything, but Subaru's. Thx Stacy
1 - 12 of 12 Posts
