1 - 11 of 11 Posts
'02 H6 Sedan - gone :(
After changing the oil this last weekend, I was doing my normal wiping down of the engine, checking the fluids, etc. When I thought, it's getting close to change the transmission fluid here soon....I ought to check to see how the color looks. Looked for a bit...no dipstick?!?!?!?
Soooooo, how do you check the transmission fluid on these? Mine is an '02 H6-3.0 Sedan.
Thanks for your help.
Liberty/Legacy 3.0R spec B
Dipstick should be there on the drivers side of the transmission (for US or left hand drive) just in front of the fire wall. It will have a yellow loop on top so as you can pull it up with your finger.
You must check the transmission oil when the car is up to temperature AND WHILST THE ENGINE IS RUNNING. It should be between the two marks on the dipstick as indicated. Read your manual for the correct procedure!
SubaruOutback.org Founder
2021 Outback Limited 2.5L - 🍦The Ice Cream Man🍦
Lance is correct, in the U.S. it is on the driver's side directly behind the engine cover and in front of the firewall. Also of note, from personal experience, DO NOT try to change the fluid out yourself unless you absolutely know for sure what you are doing ;)
Thanks...I'll "put my eyes back in & take another look". Just didn't see it the first time.:bonk:
I wasn't planning on doing myself...dealer did the recall on the transmission lock...from what i could tell they took the whole console out in addition to changing the fluid.
Wow...thanks guys...I'm not as blind as I thought. I had get the shop light out. It was hidden under some hoses.
2004, Outback H6
Transmission Oil Change
Changing the Transmission is not that bad. I have 04 OBW H6 and today I changed the fluid for the second time the last time was 30, 000 kms ago. If you buy a funnel with a built in hose to reach the Trans dipstick hole to fill the trans up no big deal to do the fluid change. The only question I have is where is the Transmission Filter located. Bought a filter at my local parts store but I can't find the filter, any help out there?
04 Outback H6
Nancydrew,
The transmission filter is located in front of the driver side wheel well / fender by the left fog light.
2010 Outback
Age has a way of getting to ones eyes but neither I nor my young son have been able to find the transmission dipstick...... Right side..... near firewall..... by Master cylinder...... got that down but NO yellow loop...............hoses moved...... it is still hiding!!!!!!!!!!!!! Any help to find the missing would be appreciated. Thanks
If your 2010 has 2.5 engine with the CVT transmission, there is no dipstick for the transmission or for the front differential.
See: http://www.subaruoutback.org/forums...-2011-2-5i-cvt-differential-fluid-change.html
The previous posts refer to the earlier 4-speed AT or the 5-speed AT. (There was no CVT at that time.)
Thanks for the fast reply......... all the research I did told me nothing... the manual had sections for manual and automatic............ only now did I find a paragraph on a separate page!!!!!!!!!!
Thanks again
1 - 11 of 11 Posts
