2000 OB Auto
Hi,
On http://opposedforces.com/ they list two oil pans for different years, one is an alternative to the other so it appears to be interchangeable.
http://opposedforces.com/parts/lega...smission/at_transmission_case/illustration_3/
31390AA080
alternate: 31390AA081
However there is also a picture:
http://static.opposedforces.com/epc_img/366495015440.png
This says NEW->OLD but NOT OLD->NEW
Anyone knows the story behind? The magnet would be different for sure but I took the OLD not for NEW means the whole package, i.e. old pan/magnet cannot be used onb new transmission. Is this a recall or design flaw in the old version?
Thanks!
I believe it comes down to the stamping and overall design of the pan. The bolt patterns are the same, but I believe the 081 pan is for the redesigned valve body (as originally designed for the 01-04 applications).
I believe the magnet location and bump-outs for the old pan won't clear the new valve body.
2000 OB Auto
Thank you RoughDiamond.
I was not aware of the valve body change. I know they changed transfer valve.
So would you say the valve body change is physical not electrical? Because I want to do the swap between 2000 and 2004.
