2002 Outback VDC H6
So I have Hella Supertones running on a Subimods harness on my 2000 Legacy GT. I've had the set up installed for over a year without any issue, but yesterday the horn went out. I checked the fuse and it was blown, and activating the horn blows any new fuse. No changes have been made to the set up. If anyone has any idea what I can do to troubleshoot this it would be appreciated as I'm an apartment dweller without a garage and it's fucking cold out...
Fresh Out of Outbacks!
Disconnect & check for a short on each of the horns with a meter. Check wiring for abrasions.
2002 Outback VDC H6
Goes into a relay. I think I found the problem.... Holy corrosion Batman! If I clean this up with that chemical spray you use on battery terminals and reconnect with dielectric grease, think that will solve my problem?
2002 Outback VDC H6
I may ditch the harness when it's warmer to spend some time on it. I cleaned up the harness with terminal cleaner, new relay and some dielectric grease and we're back in business. Thanks guys
Maybe check the mount orientation? Relays should generally be mounted terminals-down to let any moisture drain out.
