1 - 9 of 9 Posts
1996 outback, when coming to a stop, engine starts to knock like it is unbalanced, presumably running on two cylinders, then stalls. It will start immediately and run fine but when I come to a stop again it starts all over. When this starts I can keep the car going if i increase RPM's. but when i go there is very little power, feels like it is running on one or two cylinders. I have replaced plugs and wires. Engine light says misfire in 1 and 3. Is this a coil or something else electrical?
Help
IACV? Throttlebody needs cleaning? Slipped TB?
CEL on? get the code read and post here is so.
many things could cause this problem.
coil or slipped TB could be 'side specific' right?
01 Outback LL Bean
I agree. Unfortunately pulling the timing cover for that side of the motor requires removing the accessory belts.
I would pull the #1 plug and run the motor with the spark plug wire attached and see what the spark looks like.
Coil assembly triggers cylinders 1 and 2, and cylinders 3 and 4. 1 and 3 would mean that both coils inside the coil assembly are faulty. But then one might expect misfires on 2 an 4 as well.
Plugs and wires were replaced, and if there wasn't any change with this I doubt it's the type of plug or wire. (Even if the cars are sensitive, I would think that changing faulty plugs or wires should lead to different symptoms.)
1 and 3 are on the right side, so anything that is common to both left and right sides is a less likely cause.
Misfire could also be a fuel issue -- something with the right side fuel rail.
Certainly need more information about the car and engine (could it be a 2.2?) and maintenance, including TB service.
1 - 9 of 9 Posts
