First, I have to replace the drivers side low beam bulb,so I have to remove the battery.When I reconnect the battery,is there any special procedure,meaning just connect and crank? I know some vehicles have a certain procedure when you disconnect a battery.
Second,when I bought the bulb I went ahead and bought new spark plugs. I have the four cyc. Looks a bit tight on space.Any tips or tricks to replacing the plugs?(no specialty tools needed I hope)
Thanks ,Troy!
Thanks ,Troy!
