The late mode Outbacks ... mine is a 2002 ... have a two wheel drive option. If you install a specific fuse in the fuse box you convert the car from all wheel drive to front wheel drive and a light will come on on the panel saying FWD. Does anybody have any input on to whether this might prove beneficial for better gas mileage in the vehicle if you were to operate it in the front wheel drive mode?
good observation and a very common question.
since the car will weigh the same and have the same aero drag, plus, the same rotating components will be turned by road friction on the now un-powered rear wheels and thru the driveshaft and some gears - you will not detect any fuel savings.
You may also, eventually, ruin the Duty C Solenoid or other electrical component with constantly applied voltage to a system designed for temporary use when fitting an under sized or 'odd' sized tire. Your manual will explain when that fuse slot should be used. Occasionally it will be suggested to try using it to help diagnose certain problems.
The FWD fuse is not an 'option', it is a backup for when you have to do something like run an undersized donut spare on the rear of the car.
Meh.
I has wagons.
It will not improve MPG.
It is not an "option".
It is meant to limp a damaged vehicle to get repaired.
