1 - 7 of 7 Posts
2013 Outback Limited SAP
Woke up this morning to the police ringing my buzzer. My two passenger tires were slashed on my '13 OB SAP overnight.
Which leads me to my next decision... I know a lot of people hate on the Contis. Do I replace with OEM Conti's or upgrade all four? They only have 5k miles on them.
2013 Outback Limited 2.5i
YOu need to replace all 4 tires because uneven wear may cause issues with the AWD system; due to the slight difference in rotation speed.
2013 Outback Limited 2.5 EyeSight & 2010 Legacy Premium, 2010 OB Limited (traded)
With only 5k on the car you should have only wore off about 1/32" of the tread which is well within the spec for replacing just 2 tires per Subaru. Check your owner's manual but you have to do some math being they list the spec by circumference not tread depth. It should work out to about 2/32" tread depth difference allowed.
I would just replace the 2 damaged tires as long as you are within spec. Not everybody hates the Conti Pro Contacts. Here is a very good thead on them with one poster who switched to Defenders and returned to the Conti Pro Contacts:: http://www.subaruoutback.org/forums...-procontact-ecoplus-vs-michelin-defender.html
2013 3.6R SAP BBP Outback
If your tires might get slashed again, just get 2 Contis and call it good. No sense putting several hundred dollars into a full set.
2011 Outback 3.6 Premium
With a 2013 your tires are probably like new. If that's the case, just buy 2 new Conti's. Insurance may cover the cost.
yep, I agree, less than 2/32" difference, buy 2 of the same make model. especially if they go on one SIDE of the car. open diffs are your friend this time.
hope they catch the [email protected]@rd that did it.
1 - 7 of 7 Posts
