Someone out there must have had this problem, but I haven't been able to find a relevant thread, so I am creating a new one.
Last spring 2016 I bought a used 2014 Outback Premium from a Subaru dealer. It had the factory roof rack. When I mounted & loaded the rooftop carrier I'd reliably used for years on my 2000 and 2003 Outback's w/factory racks, I got a loud unbearable humming noise that started around 50 mph and wouldn't go away at higher speeds. The speed it started at seemed to be wind dependent. No amount of duct tape, jammed in towels, etc would make a difference. And it drowned out the radio. I couldn't figure out exactly which part of the rack or carrier the noise was coming from. It was definitely a vibration (harmonic?), not a rattling, loose strap or that sort of thing. I'd say that it was coming from the whole rack, although it's hard to be sure when listening from inside of the car or through the moon roof. After completing the vacation trip (under 50mph!) I emptied the carrier and found it still made noise at the same speeds. When I removed the carrier and drove with the racks cross wise I did not get any noise.
This year I bought a new Thule carrier which was longer and more streamlined, figuring it was the old carrier that was the problem. Another reason I bought Thule is that it seems that is the model that Subaru endorses. Guess what...it makes the same noise, although it seems to start at a slightly higher speed.
Has anyone out there had a similar experience? And have you found a solution?
Thanks!
Eric in Philadelphia
Thanks!
