I want to upgrade my tire for on/off road use, I did check here and find that a lot of are using YOKOHAMA Geolander GO15 A/T,
the tire right now is 225 60r18 100H MIS Dueler H/P Sport AS (the original)
but the size that is available from YOKOHAMA Geolander GO15 is 235/60R18 107H (10MM WIDER)
if this tire can fit to the outback 2015 limited or not. (what is the max size tire can fit?)
if this do not fit then I have to buy the new rim to use 225/65R17 102H
when i call YOKOHAMA, they suggest me to use Geolander GO55, what is the different? any one use it?
GIVE ME SOME SUGGESTION WHAT SHOULD I DO ON THIS.
THANKS.
THANKS.
