Hello everyone. I'm having some trouble understanding where to measure the gap with the feeler gauge. I have a 2000 outback with a 2.5, i believe it is the 252. I got everything taken off and Cyl #1 to tdc. The issue I'm running into is that I don't understand where to put the feeler gauge?
Where I think Im suppose to put it the gap is huge and I dont have a feeler big enough. I wasn't noticing any noises though, the reason im checking it is because my valve cover was leaking so I figured it was a good time to check.
Thank you for any help and I have tried reading the other threads but I'm having trouble understanding where to measure. Also how do i know which is intake and which is exhaust. Here is a picture of the passenger side of my engine without the valve cover. Again thank you for any help as it is really appreciated.
01 Outback LL Bean
Intake are on the top, exhaust are on the bottom. You measure between the end of the valve and the adjustable screw/bolt which is the adjustment point.
Wrong place, that's spark plug tube.
Are you sure you want to do a valve clearance job?
Attached is how to.
FSM here: www.main.experiencetherave.com - /subaru_manual_scans/
O.
Ya I just bought the car so Im mainly just checking them unless they are all out of whack. The valve cover was leaking so I figured when I did that it was a good time to check them. I had just never did valve clearance checks in the past and the manual I had was showing that area which is why I was getting confused. Thank you for the help.
