1 - 7 of 7 Posts
2000 Subaru Outback Limited Sedan, 2.5L
Has anyone come across any information regarding the verification of a sensor failure? For example, I'm currently getting P0113 (intake air temperature sensor). It would be easy enough to drop a few bucks on a new sensor, but is there a way to test these sensors using an ohm meter to verify a fault prior to just throwing parts at the problem? O2 sensors, or just about any other sensor with wires, would be other examples.
Banned
Something I would expect to be covered in the factory service manual.
Nothing in sensor readings on that one. The troubleshooting tree in the FSM (attached) focuses on wiring continuity and shorts between the IAT sensor and the ECM. The Subaru Select Monitor (perhaps FreeSSM or Romraider) is used to verify the code symptom.
And the resistance would likely change with temperature so you would need a chart, probably easier to verify continuity and then change the sensor.
Excellent resource plain OM. With the diagnostic troubleshooting tree you provided I should be able to confirm failure of the sensor.
Pulling the trigger on a new IAT sensor. IAT failed the last step; resistance between pin 1 of E21 and ground was only .4 ohms (replace IAT if less than 5 ohms). Thanks for the info plain OM!
1 - 7 of 7 Posts
