I have an 07 outback that i have owned for 3 months. It has an acceleration vibration my girlfriend drives it and loves it so i need to fix this problem .
Trans fluid and filter replaced 1/3/20 and it appears to have new front axles.
At first i thought it had a miss but it revs smooth as can be. So i put the fuse in the fwd spot(fwd disable), and the vibration got worse during acceleration.
Help!!
2009 Subaru Outback 3.0R Limited
Are the new front axles OEM or aftermarket? Aftermarket ones are known to cause bad vibrations.
i`m not sure when i pulled the fwd fuse the vibration is gone . i`m guessing they are not oem axles. thanks
