1 - 12 of 12 Posts
2005 Outback LL Bean Wagon 225,000 miles H6
Wanted: 2005 3.0L OBW Rear Drive Shaft Pre 5/1/05
I am in need of a rear drive shaft for a 2005 Outback LL Bean Wagon. MUST have good U-Joints. Needs to come from a 3.0 H6 or Legacy GT with 5-speed automatic and car must have build date between June 02-April 30. My U-joints are shot and dealer says they are NOT servicable on that year. Need cost with shipping to NJ 07826.
Thanks--
re: Rear drive shaft
Thanks. I just called. They do not have one. Leave it to Subaru to make it complicated. Apparently that shaft was only used for 6 months. Very narrow window to work thru.
Try F & S auto salvage in CT
2006 Outback 2.5i Limited 5MT, 1984 Porsche 944
What's different about it? I wonder if it would be easier/cheaper to swap in a later year drive shaft with say, a matching differential? Now obviously if it's the transmission is has to match with, it wouldn't be cheaper.
I have no idea. Not even sure my dealer does. I just know for 2005 they specify "before 4/30/05" or "after 5/1/05". I have a 9/04 build date. Might just have to cough up the $645 they want for an all new one at dealer. Car has 228,000 miles on it so hoping nothing else goes. Bought it right but that only goes so far.
Driveshaft shops can service or build new for less than that much... also try Car-Part.com--Used Auto Parts Market for a good used.
Just punched in the info, the tool knows about the date of the change, looks to be many available, bet you can find one for under $250 including shipping.
if it is like my '03 ****** driveshaft it is all one piece, no bolt-off rear section aft of the carrier bearing.
Still looking. Local drive shaft places told me they ship to a place in California. I cannot do that--car sitting up on lift at Subaru now.
I would get one from a junkyard via car-part, nothing wrong with a used driveshaft, and there were many I saw that will fit and will cost you less than $300 shipped.
I ordered one from VA for my H6 OBW, myself.
That is what I did. Have one coming from Wisconsin. Should be here Thursday. $175 including shipping and off a car with only 49,000 miles. Thanks.
Discussion Starter · #10 ·
Wisconsin one had bad U-Joints. Go figure, it had only 49,000 miles on it. Back to the drawing board.
Discussion Starter · #12 ·
Got one from Henderson's auto parts in Scottsdale, PA. It was installed today and WOW, what a difference. Car drives super-quite. Guess the old rear shaft was going bad all the time i had it (since 12/2012). Thanks for everyones comments and advice.
1 - 12 of 12 Posts
