1 - 10 of 10 Posts
2018 Outback 3.6 Touring
I have a 2018 Touring with the Premium audio/nav system. After a recent incident* where the battery drained completely, we started getting a weird issue with the audio system. Even though we pretty much always listen to SiriusXM, sometimes the system will switch to Bluetooth or USB on startup. After a lot of back and forth with Subaru, they first suggested a factory reset which didn't help. Now they want us to take it to the dealer for a replacement of the unit, which seems wasteful. Has anyone else run into this?
*This happened when we accidentally left the rear liftgate open overnight, this alone can drain the battery. There is now an FSB to remediate this, which we got installed.
20 Outback Premium
Try closing the music apps on your phone before getting in the car.
20 Outback Premium
Thanks. They are never open. And this issue never occured before the battery died.
I had the same problem and resolved by rebooting the phone. Sometimes problems are caused by the phone and not the car, though in your it does seem awful coincidental with a change in the car.
Yep, both phones have been rebooted, and it has also tried to go to USB despite there being no media.
20 Outback Premium
The only other solution that seems to help is to remove the phone from the car and vice versa and start from scratch. If you’re still on iOS 13 an upgrade to 14 could help.
2017 Outback 3.6 Touring, which replaced '05 Outback XT
I would disconnect the battery and then reconnect and see if a "cold boot" might fix the radio. After all, it's basically a computer.
Discussion Starter #8
That might be worth a shot to try out, thanks
Just seems like a waste to throw away the radio for a relatively minor quirk.
Discussion Starter #9
When we did the reset, we had to re-add the phones (Android) back in. I think that is what you are referring to?
1 - 10 of 10 Posts
