1 - 20 of 637 Posts
Submod , ,
2000 BMW R1150gs
Many of the other Subie forums have them so I'm starting this thread up to find out what y'all are doing to your 1st generation Subies. STICKY REQUEST
Cheers!
Submod , ,
2000 BMW R1150gs
Discussion Starter #2
My wife's car is our first subie (Redbaru) which is a '97 OB wagon. I am in the process of re-snorking it and getting it as close to stock as possible with an exception of her JDM replacement engine.
Today I installed the last few air filter parts that were taken off when I had a CAI going on in there.
1998 Legacy Outback Limited, 2.5, Automatic
i made a screen to go over my sunroof, i added another 12v outet in the back, i put in a new Knock Sensor. And i did my PCV valve. Next is to intergate a power inverter into the rear of the subie. and i am also working on plans to make a easliy removable light bar for the top.
1997 Legacy Outback
New timing belt/rollers/tensioner/water pump/front brake pads and rotors/brake and clutch fluid change. Next up, Rallitek sway-bars! (anyone have a good used set?)
15 2.5i Limited Ice Silver / 06 2.5i 5MT Atlantic Blue-Silver
I ordered one today even though they're out of stock from rallitek. I'm hoping I didn't miss out at my shot at a new one because the rep wasn't real optimistic about them getting more.
Otherwise I've been on a old Outback "firm up" mission. In the last couple weeks I've replaced all four struts, tranny mount, front end links (all of which we're beyond worn), and I have a Group N pitch mount on the way. Each upgrade has made a significant improvement in the handling and ride quality. I really hope that swaybar comes back into stock! That would be the last piece of the puzzle to complete my mission.
Submod , ,
2000 BMW R1150gs
Restored and cleared the headlamps and then installed side markers
Sway Bar arrived today!
It came! I installed it in about an hour. The picture shows it mounted in the middle position, but I settled on the softest position (closest to the end) because it didn't overpower the front as much. I can't imagine using the stiffest setting without installing a bigger front sway. Even in the middle position, the front felt too light.
Edit 9/15/11: After getting used to the "soft" setting, I found myself wanting even less roll, so I moved it back to the middle. Now that I think about it, one of the things that surprised me initially with this car was how heavy the front felt in corners. Now I'm embracing the lighter front end feel I was used to in my Accord. I wouldn't be surprised if I go the the stiffest setting on the sway before too long!
Edit to the edit 9/16/11: Yup, it took only one day for me to put it on the 25mm setting. It's amazing how much difference it makes! The whole car feels so much more solid, and it corners likes it's on rails! Best bang-for-your-buck mod for this gen of Outbacks.
I also installed the STi pitch mount, and that makes a nice improvement in acceleration off the line. I'm thinking about installing the matching transmission mount (in an effort to eliminate the lashing in the tranny when letting off the gas), but I think it would add more noise and vibration than I want.
2014 OBW 3.6R Limited, 1997 OBW 2.5L Auto (sold, but not forgotten), and 1991 Ford F150
Now that the kids are back in school, it's safe to come out of the house. Getting ready for a 2,500 light year ... um ... 2500 mile road trip:
-changed oil/filter
-drained-n-filled trans
-renewed fluid in power steering (first time ever) using turkey baster method.
-rotated tires, checked air pressure
-filled windshield washer reservoir
-added distilled water to battery
-flushed cooling system and refilled.
-checked oil level in front and rear differential ... OK
-checked brake fluid tank ... OK
-replaced flux capacitor tubes
-cleaned and charged worm hole generator
-took her out for a wash-n-wax
Ready to go!
Edit: car ran perfectly, including on some pretty hairy hills, i.e. CA-Hwy120 eastbound from the valley into Yosemite, from Yosemite Valley up to Glacier point, and CA-Hwy299 westbound out of Redding. Very happy with my car.
Cleared headlights, and finally decided to remove the fog lamp guards. It just drove me nuts that I could never get them clean with them on. With the PIAA driving lights, I can really light up the night!
1998 Outback lifted Limited on 28s
I thrashed my ride over the weekend and came to the conclusion I REALLY need a bash plate/ skid plate and a Low Range if I'm gonna continue having a lot of fun with her. Checked for damages and realized I bashed my oil pan, destroyed my drivers axle and steering boots,bent up my pinch weld and rockers on my drivers side as well and bent my heavy duty bumper when I had the front end held up by the side of it on a rock. Have videos and hope to post sometime within the next week. Have picks of my pan though.
:gasp::eek::gasp::eek:
Did better than I expected though:29:
You have an interesting take on the interpretation of the question "What did you DO to your 1st gen OB today?" :)
Sorry, forgot to finish that I replaced my drivers side steering rack boot and discovered my axle boot is trashed. Also did an undercarriage look over to see what other damages I did.
1995 legacy LS wagon automatic
recommendation for new struts/shocks
Hi Gotsquat,
Is there a recommendation for a good replacement for the struts/ shocks?
Are there any other suppliers for upgraded rear sway bars?
Do you have a lead for replacement bushing suppllies? ive found some polyurethane ones online- havent ordered yet at: Subaru Legacy (1995 - 1999) Urethane Bushings -- PowerflexUSA Online Store
Thanks for any help,
Scott
P.S.- gotsquat, watch out that you don't use more amps than your alternator can put out, all those lights, wipers, fan, rear defrost etc really add up. Each 50 watt bulb burns off 5 amps more or less.
I has wagons.
Outback.
Hi Gotsquat,
Scott
I used KYB GR-2 struts and they work great.
I don't know of any other good sources for RSB, but I didn't look real hard since the Rallitek was such a great deal (comes with new endlinks and bushings).
Haven't tackled any of the other bushings, but it looks like that's a good source.
I only use the driving lights when I really need it and never with the stock fogs at the same time. It just looked cool to take a picture of it!
Few most recent things i got done..
-lowered on 03 wrx wagon struts/springs in rear and eibach lowering springs w/03 wagon shocks up front.
-Cleared the front sidemarkers, through in v-led 92smt switchbacks(white running and turns orange for blinkers)
-JDM headlights
-JDM grill
-v-led 6k HID high beams(already had 3k hid fogs, 6k lows, 6k reverse hids w/ reverse override switch) -all v-led, 92smt led running/stop bulbs, orange 7W highpower led bulbs in rear turn signals, led liscense plate bulbs
-pioneer 4300 deck, JL audio speakers, amp and sub....it pumps now!
-Compustar 1mile autostart w/ alarm system w/ 2way lcd screen remote
-tinted the rear tails
-higher output alternator(110 or 115amps vs stock 85amps)
-ralliltek 22mm adjustable RSB
-removed roof rails and had my shop paint roof gloss black(will throw rails back on when winter comes so i can put my dual angle inno snowboard rack up top) roof rails were sanded and painted gloss black aswell
thought this was worth mentioning, subaru ftw
Work in progress, New light bar, Fog lights PIAA, new crossbars, tinting windows.
To Do:
- Install new wheels
-buy new tires
- maybe throw some hella's driving lights
-change the stock headlights bulbs into HID
1997 OBW w/213,000 miles
Gave the wife's 97 a pair of $ilver$tars over the weekend, will restore the lenses this coming weekend. She already notices the difference at night... But she has the habit of ALWAYS driving with the headlights on...i hope she gets at least a year out of 'em...
'97 Outback Wagon 2.5 5-speed I saved from junkyard!
I had to install a new water temperature sensor for the emission system. The old one threw a code, and it intermittently went into an over-rich condition like the engine was cold, even when it was hot. Of course, it couldn't be a simple fix like most normal cars; this required removal of the intake manifold to get to the sensor. Grrr...:mad:
All better now, though.
1 - 20 of 637 Posts
