6961 - 6972 of 6972 Posts
2008 Outback 2.5l AT and LPG fueled
Lucky that it happened when your tire tread is already low. Time for 4 new tires!
Not at all. Tires have still 7 mm of tread and will replace only this particular tire. Tread difference to new tire is approxx 2-3 mm wich should be ok for the diff.🤓 For additional peace of mind I'll inflate the new tire with 1 or 2 psi less than the others.
2019 Outback Limited 2.5 // 2009 OBXT 5MT - R.I.P.
Must be the angle, that tire looks bad :/
06 LL Bean 3.0 R
First I changed my serpentine belt (5 minutes)
Then I set about replacing the three large radiator hoses which had become swollen and squishy. While working the final hose onto the radiator, I discovered that the radiator is fatigued and quite brittle. The more I look at it, the more I think it may have been cracked before I started the hose swap. In the event that fitting is replaceable, please let me know where to get one so I don't have to buy a radiator.
Motor vehicle Vehicle Automotive air manifold Automotive exterior Automotive design
while I have read of rad. shops having tools to crimp new plastic tanks onto cores, I doubt it's a good way to proceed vs a new radiator. Have you priced them? Koyo, Denso from aftermarket should be fine.(RockAuto, Amazon, etc. AdvanceAuto used to have a nice coupon for first time buyers on-line.....)
I put a new rad in my WRX due to leaking at the tank/core seal and never looked back.
What 1 lucky texan said. Even though you might be able to repair that part the rest is of the radiator is probably suspect too. Better off getting a replacement radiator.
