Picked up my OBWilderness from the dealership yesterday after the big updates.
My local Subaru dealership replaced my head unit and updated my transmission with the new TSB 16-135-21R software update.
The head unit kept blacking out and rebooting after the first update.
It was a little bit faster but it was still having the rebooting issue.
I also let them know the heat was super hot as per the temperature.
They told me that the heat related issue has to do with the cockpit controls module.
I was also noticing the lack of power response with the gas pedal. My best description is like if it is hunting for a gear. It is slow to think and when it makes up its mind it rips like a bat out of ****. Some people would say it is turbo lag but I believe the stock turbos are too small to have that much lag. It’s not like we are pushing 60mm plus turbos.
I came out of an 2019 Ascent. I have had my fair share of experience with the same 2.4 engine and CVT transmission set up. I understand they are geared different but it is basically the same set up.
The Ascent went through tons of software updates in regards to the transmission. They kept updating and cleaning it up a little bit every software release but still had room for improvement.
My first impression after picking it up was how responsive the head unit was. I did not have to unplug and re-plugged my phone cord in order to get the Waze to work correctly. Short ride home so I did not get a chance to see if it rebooted after 20 to 30 minutes.
The transmission TSB software update seem to smoothen the acceleration a bit. It feels a whole lot better and more linear than it did before. Even the technician felt it on the test drive and made a note of it. Hopefully they will continue updates like they did with the Ascent too further clean it up.
The transmission TSB indicates it is specifically for the OBWilderness. This update was incorporated into the production of the OBWilderness starting with VIN N3155224.
I wonder when is the build date start to this Vin. I do not believe this is an across-the-board Gen 6 Outback 2.4 software update unfortunately.
https://static.nhtsa.gov/odi/tsbs/2021/MC-10203874-0001.pdf
