@Freakmech looks good with red engine dress up. Do you have part number for the two hood bumper/bushings that are in red? Thanks.Perrin and Grimmspeed engine bling.
Perrin SKU: PSP-BDY-010RD@Freakmech looks good with red engine dress up. Do you have part number for the two hood bumper/bushings that are in red? Thanks.
I tried updating my maps using a USB drive with an update from the Map Downloader program, and the version number on the maps screen did update. However, the individual state maps did NOT update, in fact they all seemed to revert to the previous version. Any ideas?I updated the nav maps today. Before starting, I hooked up my NOCO 5 charger. Even so, the car shut off about 2/3 of the way through the update. So, restarted it and finished the job. It probably took about 90 minutes or so.
Did you do the update in accessory mode or with the ignition on and engine off?I updated the nav maps today. Before starting, I hooked up my NOCO 5 charger. Even so, the car shut off about 2/3 of the way through the update. So, restarted it and finished the job. It probably took about 90 minutes or so.
I also updated the maps (today) with a USB as you did, and found the same thing. I seem to recall that happening for the last update too, but I'm not sure how it got resolved. Maybe the engine has to be started and run for a while (it does say the updates will be applied at the next engine start, or something to that effect).I tried updating my maps using a USB drive with an update from the Map Downloader program, and the version number on the maps screen did update. However, the individual state maps did NOT update, in fact they all seemed to revert to the previous version. Any ideas?
I edited my original post above, might answer it?I also updated the maps (today) with a USB as you did, and found the same thing. I seem to recall that happening for the last update too, but I'm not sure how it got resolved. Maybe the engine has to be started and run for a while (it does say the updates will be applied at the next engine start, or something to that effect).
Ignition on, engine off. Also lights, AC, and seats off.Did you do the update in accessory mode or with the ignition on and engine off?
You really have to overcome the impulse to over tighten a fitting with a rubber seal. More likely to leak and as seen here difficult to remove later, once you get to the point of metal-on-metal contact.I've changed oil on a lot of Toyota, Honda, Nissan, and Subaru. But the Corolla Oil Filter is one thing that I can never get off. I gave up after 1 hr trying (that felt like a long day of bicep/tricep/shoulder workout at the gym) and sent the Corolla to a local shop and they had to torch it up a bit to move with their couple-feet-long breaker bar to get it off. They told me that somehow, most Corolla are overtightened by dealers. We sold that car at the next oil change interval and got an ImprezaLoL
How much faster is it now?Perrin and Grimmspeed engine bling.
I must have missed it…I just dyno’ed the OB and it’s pulling about 25 more hp
I just dyno’ed the OB and it’s pulling 25 more hpHow much faster is it now?
l was jokingI must have missed it…
What change(a) did you make which resulted in 25 more hp?
