"car off" meaning ignition switch at Off, key out, and all switches/light controls etc Off?
As the wiring diagram above shows, the back-up lights etc are powered through fuse #18 in the cabin fuse box. Fuse #18 is powered only when the ignition switch is at On.
Fuse #8 (20 Amps) in the engine compartment fuse box isn't for the back-up lights. (It's a translation issue.) Rather, fuse #8 is an always-on "backup" power source. It supplies:
Auto A/C control module
Body integrated unit
Interior light
Spot map light
Audio
Clock
Keyless entry control module
Step light LH
Step light RH
Luggage room light (Wagon model)
Trunk room light (Sedan model)
Thanks, that makes a heck of a lot more sense. I grabbed the fuse descriptions from here:
Fuse box diagram (location and assignment of electrical fuses) for Subaru Outback (2005, 2006, 2007, 2008, 2009).
fuse-box.info
I guess I should have confirmed the descriptions elsewhere. I also notice now that I added an "s" above, it says "Backup light" not "Backup lights" for Fuse #8 in the engine compartment.
And by "car off", yes ignition off, keys in the house, all doors closed and all lights off.
The total parasitic draw is 275mA, so something is up.
I did the fuse-pulling test on the instrument panel fuse box and found that:
-Pulling fuse #6 INCREASES current draw, it was +50mA and climbing when I replaced it
-Fuse #7 is drawing 100mA
-Fuse #27 is drawing 100mA, but when I replaced it my meter showed a value 147mA LOWER than the current before I pulled fuse #27. I suppose something could have reset and I wasn't exactly patient about waiting to see what would happen. But the current draw did not change while I pulled and replaced the rest of the fuses, #28-33.
I did do the cabin test with the door open, I turned off dome light but the lights in the bottom of the doors were still on. I had 763mA at that point. I was getting cold and rather than figuring out how to disable those I assumed I could just take differential readings, but maybe I was assuming something I shouldn't have, since I tallied up 330mA with the door open and only showed 275mA at the battery with just the hood open. When I finished and closed the door the meter was right back to 275mA.
