I do not believe in a best oil / best oil filter. I do believe there are a lot of bad oils and many fair to average oil filters. There are a few wise rules to follow when it comes to motor oil and filters.
1) Unless you have a degree in organic chemistry and / or automotive engineering, always use the weight of motor oil that is recommended in your owner's manual.
2) Always use a leading brand motor oil with the API rating recommended in your owner's manual. If you don't understand why, you need to visit this website.
http://www.pqiamerica.com/
3) With apologies to Brucey, if you are going to use a cheap filter, never, ever, go over the recommended oil change interval. Cheap filters are designed to be, well, cheap. Cheap filters are not designed to hold up for very long. They are not designed to excel in any way. They are designed as an option for cheap people who are looking for cheap car maintenance. There are many a report of cheap filters failing when they are used for much over 6,000 miles. If you want to run extended oil change intervals, you better use a NAPA Gold / Wix, NAPA Platinum, Fram Ultra, Amsoil, Mobil 1, Micro Green, or some other filter that the manufacturer specifically states as being designed for extended oil change intervals.
There are over a dozen documented cases of owners driving more than a million miles on their car. Of those, there are two of them that the type of motor oil is documented. The others may be also, but I haven't been able to find anything on them. The best documented of the two is a BMW that was ran exclusively on Mobil 1. The reason it is so well documented is it was ran as part of a study by Mobil. The other is a '65 Volvo that was ran on Castrol until Castrol GTX was introduced in '67, and from that time on was ran exclusively on GTX. By the way, that Volvo has went over 3 million miles. So, I guess some could argue that Castrol GTX is the best motor oil on the market. It is interesting that none of the "premium" motor oil brands, such as Amsoil, Royal Purple, or Red Line, have reported being used in any of the million mile cars. You would sure think they would if they could. But they haven't. So it seems reasonable to surmise that, except for extended oil change intervals, there is absolutely no reason to spend your hard earned money on premium motor oils when Castrol GTX is documented as lubricating the longest lasting car on record.
