This is tucked behind the glove box along the firewall on the passenger side of the car. I found this in my Impreza too, but on the driver side (if I remember correctly). Both were unplugged when discovered.
I believe they put the ECU into a test mode. It cycles relays and will cause your check engine light to flash. Leave them unplugged unless you're dying to see what happens .
Dealer check connector, Designed to allow service personnel an ability to run test emmissions and control sensors/and devices from the service techs stall, on Gen. 1 and 2 Legacy/Outbacks it is under the drivers dash, on Gen 3 it is under passenger dash, and should be tucked below the carpet, on Gen 4 it has been eliminated as a connector under the dash.
Thanks for the replies and information. They are tucked away, I found them (whiloe changing my cabin filter) and remembered them from my Impreza so I figured it was something intentional.
Thanks again.
1 - 9 of 9 Posts
Subaru Outback Forums
Welcome to the Subaru Outback Owners Forum, we have tons of information about your Subaru Outback, from a Subaru Outback Wiki to customer reviews.
