O3 Sub Outback Wagon 2.5L AWD 4EAT w/ All-weather Package
Hi all
What is the sensor below the alternator on my 03 2.5? I thought it was the oil pressure switch as it is leaking oil, but part I got has a nipple that is way to big?
Fresh Out of Outbacks!
The sensor under the alt is definitely the oil pressure switch for the idiot light on the dash. Couldn't tell you why a replacement doesn't look right, unless it's just a goof, wrong part etc.
2003 OBW 2.5L 4EAT
Get an OEM sensor from the dealer. If you bought an aftermarket oil pressure switch that may be the problem.
Probably the crank position sensor.
Crank sensor is screwed down just above the crankshaft pulley under the alternator, but it shouldn't have any "leak". It bolts to a portion of the block that is dry unless something is leaking above it and running down.
The oil pressure switch will either leak around the threads or through it allowing for oil to pool on the block.
