1 - 2 of 2 Posts
So i’m looking to put larger, All-Terrain tires on my stock 2016 Outback Limited. What is the biggest I could fit?
2020 Onyx
235/60-18 or 245/55-18 have fit for others.
245/60-18 will usually rub.
If you have the 4 cylinder I would recommend sticking with 225/60-18 because bigger tires will decrease torque and acceleration - an all terrain tire like the Falken Wildpeak A/T Trail has square shoulders and even in the stock size looks meaty. Also consider the weight of your tire choices. Heavier tires will likewise decrease performance.
If you must go bigger then 235/60-18 is a safe and common choice, but a bigger tire will mean your spare tire will be mismatched in diameter even more than before.
Many many threads about tire size.
Reactions: HeyChris
1 - 2 of 2 Posts
