1 - 2 of 2 Posts
192k, LL Bean. Not much more color on the car so far, other than a description that it's in great shape, everything works "right". Asking $3,500 (I know...need more info to know if the price is good, or not). From a quick look this morning, appears that head gaskets may be an issue. Can someone clarify? Other things to look for, worry about? Thanks.
I'll list some stuff to watch for, do a search for more info. Dunno what your experience is with cars in general - all older cars can exhibit typical problems with worn-out parts. The H6 is does not have a reputation for headgasket problems (though, an old subaru could have any problem any other car could have)
torque bind (can be major $$$$$$)
split axle boots
vibration from poorly rebuilt axles
worn/blown bushings - rear liquid filled bushings on front lower control arm
air/foam/bubbles in power steering fluid
speed sensor on a/c compressor
bad bearings in serpentine belt pulleys (idler and tensioner)
(at that mileage - might be a good idea to have a valve adjustment done)
you could post your city and maybe someone can recommend a mechanic that would inspect the car for $75-$100 .
1 - 2 of 2 Posts
